service [accounting-migration-on-roaming|allow-ht-only|allow-open-passpoint| client-load-balancing|cred-cache|eap-mac-mode|eap-mac-multicopy|eap-mac-multikeys|eap-throttle| enforce-pmkid-validation|key-index|monitor|radio-crypto|reauthentication|session-timeout| tx-deauth-on-roam-detection|unresponsive-client|wpa-wpa2|show]
service accounting-migration-on-roaming
service [allow-ht-only|allow-open-passpoint|cred-cache [clear-on-4way-timeout|clear-on-disconnect]| eap-mac-multicopy|eap-mac-multikeys|enforce-pmkid-validation|radio-crypto|reauthentication seamless| session-timeout mac|tx-deauth-on-roam-detection|show cli]
service eap-mac-mode [mac-always|normal]
service eap-throttle <0-254>
service key-index eap-wep-unicast <1-4>
service monitor [aaa-server|adoption|captive-portal|dhcp|dns]
service monitor [aaa-server|adoption vlan <1-4094>|captive-portal external-server]
service monitor [dhcp|dns] crm <RESOURCE-NAME> vlan <1-4094>
service unresponsive-client [attempts <1-1000>|ps-detect {threshold <1-1000>}|timeout <1-60>]
         service wpa-wpa2 exclude-ccmp
| accounting-migration-on-roaming | Enables migration of accounting session information and data usage
                        details from one AP to another for roaming clients.  When a client roams from AP1 to AP2, accounting for the client stops on AP1 and is resumed only after AP2 authenticates with the accounting server. By enabling this feature, accounting session information and data usage details migrates to the new AP, and the AP does not have to re-authenticate with the accounting server. Note: Accounting session
                           information is supported on all WiNG APs. In case of controllers, this
                           feature is valid only when APs use the controller as a proxy.
service [allow-ht-only|allow-open-passpoint|cred-cache [clear-on-4way-timeout| clear-on-disconnect]|eap-mac-multicopy|eap-mac-multikeys|enforce-pmkid-validation|radio-crypto| reauthentication seamless|session-timeout mac|tx-deauth-on-roam-detection|show cli]
| allow-ht-only | Only allows clients capable of High Throughput (802.11n) data rates to associate. This option is disabled by default. |
| allow-open-passpoint | Enables non-WPA2 security for passpoint WLANs. This option is disabled
                        by default. For more information on passpoint policy and configuration, see Passpoint Policy.  |
| cred-cache [clear-on-4way-timeout| clear-on-disconnect] | Clears credential cache based on the parameter passed
| eap-mac-multicopy | Enables sending of multiple copies of broadcast and unicast messages. This option is disabled by default. |
| eap-mac-multikeys | Enables configuration of different key indices for MAC authentication. This option is disabled by default. |
| enforce-pmkid-validation | Validates the Predictive real-time Pairwise Master Key
                           Identifier (PMKID) contained in a client‘s association request
                        against the one present in the wpa-wpa2 handshake. This option is enabled by
                           default. This functionality is based on the Proactive Key Caching (PKC) extension of the 802.11i EEEE standard. Whenever a wireless client successfully authenticates with a AP it receives a Pairwise Master Key (PMK). PKC allows clients to cache this PMK and reuse it for future re-authentications with the same AP. The PMK is unique for every client and is identified by the PMKID. The PMKID is a combination of the hash of the PMK, a string, the station and the MAC addresses of the AP.  |
| radio-crypto | Uses radio hardware for encryption and decryption. This is applicable only for devices using Counter Cipher Mode with Block Chaining Message Authentication Code Protocol (CCMP) encryption mode. |
| reauthentication seamless | Enables seamless EAP client reauthentication without disconnecting client after the session has timed out. This option is enabled by default. |
| session-timeout mac | Enables reauthentication of MAC authenticated clients without disconnecting client after the session has timed out. This option is enabled by default. |
| tx-deauth-on-roam-detection | Transmits a de-authentication on the air while disassociating a client because its roam is detected on the wired side. This option is disabled by default. |
| show cli | Displays the CLI tree of the current mode. When used in the WLAN mode, this command displays the WLAN CLI structure. |
| eap-mac-mode | Configures the EAP and/or MAC authentication mode used with this WLAN. This option is enabled by default. |
| mac-always | Enables both EAP and MAC authentication. MAC authentication is performed first, followed by EAP authentication. Clients are granted access based on the EAP authentication result. If a client does not have EAP, the MAC authentication result is used to grant access. |
| normal | Grants client access if the client clears either EAP or MAC authentication. This is the default setting. |
| eap-throttle <0-254> | Enables EAP request throttling. Use this command to specify the maximum
                        number of parallel EAP sessions allowed on this WLAN. Once this specified
                        value is exceeded, all incoming EAP session requests are throttled. This
| key-index eap-wep-unicast <1-4> | Configures an index with each key during EAP authentication with WEP.
| wpa-wpa2 exclude-ccmp | Configures exclusion of CCMP requests when the authentication mode is set to tkip-ccmp. When enabled, it provides compatibility for client devices not compliant with tkip-ccmp. This option is disabled by default. |
| monitor | Enables critical resource monitoring. In a WLAN, service monitoring enables regular monitoring of external AAA servers, captive portal servers, access point adoption, DHCP and DNS servers. When enabled, it allows administrators to notify users of a service‘s availability and make resource substitutions in case of unavailability of a service. |
| aaa-server | Enables external AAA server failure monitoring. When enabled monitors an external RADIUS server resource‘s AAA activity and ensures its adoption and availability. This feature is disabled by default. |
| adoption vlan <1-4094> | Enables adoption failure monitoring on an adopted AP. Also configures a
                        adoption failover VLAN. This feature is disabled by default.
 Configure a DHCP pool and gateway for the failover VLAN. Ensure the DHCP server is running on the AP. Also ensure that the DHCP pool is configured to have less lease time. When this feature is enabled on a WLAN, it allows adopted APs to monitor their connectivity with the controller. If and when this connectivity is lost, all new clients are placed in the configured adoption failover VLAN. They are served an IP by the DHCP server running on the AP. In this situation if a client tries to access a Web URL, the AP redirects the client to a page stating that the service is down. When the AAP‘s link to the switch is restored, clients are placed back in the WLAN‘s configured VLAN, and are served an IP from the corresponding configured DHCP server (external or on the AP/controller).  |
| captive-portal external-server | Enables external captive portal server failure monitoring. When enabled,
                        monitors externally hosted captive portal activity, and user access to the
                        controller or service platform managed network. This feature is disabled by
                           default. When enabled, this feature enables APs to display, to an externally located captive portal‘s user, the no-service page when the captive portal‘s server is not reachable.  |
| monitor | Enables DHCP and/or DNS server monitoring on this WLAN. |
| dhcp | Enables monitoring of a specified DHCP server. When the connection to
                        the DHCP server is lost, captive portal users automatically migrate to a
                        pre-defined VLAN. The feature is disabled by default.  Use the crm keyword to specify the DHCP server to monitor.  |
| dns | Enables monitoring of a specified DNS server. When the connection to the
                        DNS server is lost, captive portal users automatically migrate to a
                        pre-defined VLAN. The feature is disabled by default.  Use the crm keyword to specify the DNS server to monitor.  |
| crm <RESOURCE-NAME> | This keyword is common to the ‘dhcp‘ and ‘dns‘ parameters.
 Once enabled, the CRM server monitors the DHCP/DNS server and updates their status as ‘up‘ or ‘down‘ depending on the availability of the resource. When either of these resources is down the wireless client is mapped to the failover VLAN and served with the ‘no-service‘ page through the access point.  |
| vlan <1-4094> | This keyword is common to the ‘dhcp‘ and ‘dns‘ parameters.  After
                           specifying the DHCP/DNS sever resource, specify the failover VLAN.
timeout <1-60>]
         | unresponsive | Configures handling of unresponsive clients |
| attempts <1-1000> | Configures the maximum number of successive packets that failed
                           transmission
| ps-detect {threshold <1-1000>} | Enables the detection of power-save mode clients, whose PS stats has not
                        been updated on the AP. This option is enabled by default.
| timeout <1-60> | Configures the interval, in seconds, for successive packets not
                        acknowledged by the client
nx9500-6C8809(config-wlan-test)#service allow-ht-only
nx9500-6C8809(config-wlan-test)#service monitor aaa-server
nx9500-6C8809(config-wlan-test)#service accounting-migration-on-roaming
nx9500-6C8809(config-wlan-test)#show context wlan test ssid test vlan 1 bridging-mode tunnel encryption-type none authentication-type none service accounting-migration-on-roaming service monitor aaa-server service allow-ht-only controller-assisted-mobility nx9500-6C8809(config-wlan-test)#
| no (wlan-config-mode) | Removes or reverts to default WLAN settings configured using the ‘service‘ command |
